Hey Guys, so I own a 2ZZ-GE Corolla T Sport, the issue is, there seems to be very little aftermarket support with different regions getting different versions, XRS Sedan in USA, Sportivo elsewhere etc, with all being similar yet slightly different.
I was wondering does anyone know if the engine bay is interswappable, I.e parts such as cold air intake, the celica has a slightly different of arrangement where the airbox is and the Battery etc so I assume they aren't but the XRS seems to be the same although it's a sedan rather than the hatchback.
If anyone has any experience let me know 🙂
I was wondering does anyone know if the engine bay is interswappable, I.e parts such as cold air intake, the celica has a slightly different of arrangement where the airbox is and the battery etc so I assume they aren't but the XRS seems to be the same although it's a sedan rather than the hatchback.
The only problem with the cold air intake on a xrs is some of them pass through a hole that sits In the wheel arch,on a t sport there is a air pump sitting in this hole,I think the sportivo is the same as the xrs that it doesn't have the air pump,you can k&n or blitz intakes to fit the t sport
Okay yeah I didn't think of the air pump, god I hate that some things will work and some won't, suspension wise they're all the same except the compressor model I believe.
Depending on what sort of parts you need Amayama have a a good range. I used them for the parts I bought for my GT86.
There are plenty of parts for the 2ZZ, what is your location ?
That would be my issue, I live in Gibraltar, its a small little county and so far I've seen one other T Sport, but I'm pretty close to Spain
Will check them out
I actually found it worked out cheaper than walking 100 yards up the road to my local Toyota dealer.
