Error message
Pmorl5
Hi recently had 3 error messages check engine check 4x4 and trc took it to local garage they scanned it came back erg valve so replaced it cleared the code test drove it and the same message came up since had it smoke tested to no avail it only gets the message if you put it under pressure any ideas would be greatly appreciated it's a 2010 2.2d4d
The triumvirate of warning lights is misleading - it is probable that the 4x4 check and TRC lights come only because the check engine light has. You would need to read the actual error code or codes to understand what it is trying to tell you.
After driving really hard got a p0093 code any ideas as there is no fuel leak
