2005 Rav 4 loses power
K Ashmore
Hi any suggestions why my Rav 4 loses power when driven around 70mph nothing shows up when it is plugged into   Diagnostic machine at garage but happens when overtaking on a motorway and I have to pull over and restart engine
Hi - I'd start by changing the fuel filter and see if that helps.
Good luck
Hi Matey
What milage on the clock ?
I ve had similar issue recently but with petrol engine and no any alerts have been shown on the scanner screen. Finally the fuel pump has burnt out (along with fuse) and I was forced to change both filter and pump. MrT could not make an access cover under rear seats to change it (!!!!!!!!!!!!) and it is necessary to lover fuel tank.
regards \ Igor
