Hi All, been a while, just curious about service on my Estima, i have 125000KM on the clock and its 2012.. i believe the Iridium sparkplugs are long life  span so are they due a change by now ? Are you better of changing them every service anyway ? Any advice welcome with thanks
They normally last a very long time; I think the interval is usually around 60,000 miles depending on the car.
If there's no history of them being changed might be worth it just to head off any potential future issues. They're not that expensive anyway...
That's perfect thanks ill just change them so to be sure
If you’ve a CVT transmission, I’d get the oil changed - properly. There’s a special procedure to extract all oil (alternative is to replace a couple of times).
Okay thanks paulcarbs also, i will be enquiring about the oil  procedure too
