Disc brake question regarding my Toyota C-HR 1.2T
Hi all
I picked up my 2018 Toyota C-HR a few months back and have now noticed that the passenger rear disc brake is all scored looking.
A grinding noise is coming from it that I can hear when the window is down even at low speeds. I can also hear a whining as If the wheel bearing has started to go from the same wheel when I am going above 35mph.
Does the Hybrid version have different disc and brake pads than the 1.2T 2WD model?
I have been searching online and noticed a listing for a set of rear pads and discs on eBay, which actually states that it will fit my car in the listing and fitment guide.
I emailed the seller with my registration and he came back and said that it was actually a set at over 2 times the price that I would need.
I usually use Europarts when buying car parts the majority of the time... but they do not list any disc brakes for my car on there website. The listing for brake pads actually has 2 different sized brake pads.
Unfortunately money is tight so I don't have money to waste.
Any help would be appreciated.
Alex
5 hours ago, Cookatron said:
Hi all
I have been searching online and noticed a listing for a set of rear pads and discs on Ebay, which actually states that it will fit my car in the listing and fitment guide.
Alex
you brake discs number is 42431-78010, you can check in eBay and there are plenty of choices and not too expensive.
Number for your brake pads is 04466-10010, also plenty to choose and even original for £32.99 . If you are buying original from eBay make sure you only buy from authorised Toyota retailers main dealers otherwise you may end up with fake parts.
https://www.ebay.co.uk/itm/264485101334?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=vV-jwrewS2G&sssrc=2349624&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
https://www.ebay.co.uk/itm/234516281779?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=yi1ojZncSxy&sssrc=2349624&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
Blueprint are very high quality aftermarket parts as good as original one.
Here the catalog to look by yourself and make sure you are getting correct parts http://www.catcar.info/toyota/?lang=en&l=bWFya2V0PT1ldXJvfHxzdD09NzB8fHN0cz09eyIxMCI6IlJlZ2lvbiIsIjIwIjoiRXVyb3BlIiwiMzAiOiJDLUhSIDUyODUxMCIsIjYwIjoiTkdYMTBSLUFIRkRYVyIsIjcwIjoiNDctMDcgUkVBUiBESVNDIEJSQUtFIENBTElQRVIgJiBEVVNUIENPVkVSIn18fGNhdGFsb2c9PTUyODUxMHx8cmVjPT1BMXx8bW9kaWZuYW1lPT1OR1gxMFItQUhGRFhXfHxlbmdpbmU9PThOUkZUU3x8bW9kZWxubz09MDEyfHxQcm9kUGVyaW9kPT0yMDE2MTA5OTk5OTl8fG1vZF9pbmZvMD09TVRNfHxtb2RfaW5mbzE9PTZGfHxtb2RfaW5mbzI9PVJIRHx8bW9kX2luZm8zPT1EfHxtb2RfaW5mbzQ9PUVVUnx8cGFnZTYwPT0wMDJ8fGdyb3VwX2lkPT00NzA3fHxwYWdlNzA9PTA%3D
also very important when changing disc and pads is to strip everything and clean to bare metal , hub bearings , pads shims , slider pins ! Only use silicone grease on the slider pins and do not use grease anywhere else, this is important step or you are risking to have vibrations 2000 miles after new parts are fitted.
  • 4 weeks later...
Hi Tony
Thanks for the reply.
I was informed that the disc brakes on my car are bigger than the quoted 281mm size above (291mm or 292mm cant remember).
Firstly from that Ebayer seller mentioned above and then from a local garage who gave me a quote.
The garage said that the parts where a pain to source for my vehicle.
The local garage quoted me £400 for new discs, pads and a new bearing fitted... which is obviously expensive.
Toyota quoted me £250 for just new pads and discs to be fitted or £180 for the pads and discs themselves.
I was half inclined to just pay the £180 roughly for the pads and discs from Toyota and have a go fitting them myself.
At least then I would know that they fit.
I have bought parts before and went to the time and effort of fitting them, to then find out they do not fit and you have wasted time stripping the parts off.
Alex
11 minutes ago, Cookatron said:
Hi Tony
Alex
Hi Alex,
in this case you have no option but original Toyota parts only. I did check some places and nothing is available aftermarket. If whoever looked at your car is correct your brake system is made by TRW and indeed the parts are different from what I give you previously.
https://apecautomotive.co.uk/catalogue/
https://www.autodoc.co.uk/spares-search?keyword=Dsk3849
pads are available aftermarket, if me I will probably buy textar https://www.autodoc.co.uk/spares-search?keyword=Pad2375
There are two types of pads and discs on CHR, PM me with reg number for price on genuine ones
