Im transplanting a Altezza beams 3gse engine and I want to remove the old aluminium sump and make a new sump to clean up the look I can fit the older oil pump and fit oil filter to block but what will I do about the crank sensor as the older pump has no mount for it
Have a look at Surfab or Moroso 3gse sumps
