Mk4 Hidden Centre Speaker
W1P30UT
While trying to resolve some dashboard rattles, I noticed the MK4 (Design spec for me) has a hidden central speaker. I don't think it's active, but is connected. Is there a way to make it active? I wish the MK4 had better sound quality from it's media system. I don't need lots of thumping bass, just closer to a hifi standard.
Best wishes.
Not part of the e-call system?
As noted by @FROSTYBALLS the speaker is solely for the E-call system and is purposely segregated from the Audio system to ensure functionality should the cars power be cut in an accident for example
  • Like 4
IIRC where I was looking at a parts diagram there is a separate small Battery near the SOS button / DCM - any idea if that provides power to the E-call system if the vehicle suffers a loss of its 12 volt power supply.
It’s not hidden if you’ve found it! 😂
  • Haha 1
Didn't look easy to get that grille off 😱 Was that the source of the rattle?
It wasn't easy to take off, and wasn't the solution either. It's further in to the dashboard. I've posted here.
On 7/6/2022 at 8:03 PM, forkingabout said:
IIRC where I was looking at a parts diagram there is a separate small battery near the SOS button / DCM - any idea if that provides power to the E-call system if the vehicle suffers a loss of its 12 volt power supply.
You're correct, when I disconnected the speaker the SOS system had a red light rather than green.
On 7/6/2022 at 10:43 AM, W1P30UT said:
Best wishes.
did you see what colors are on the cables to the speaker
