Yaris MK4 dashboard removal instructions
W1P30UT
I am trying to resolve a rattle on my dashboard. I know roughly where it is and the cause (near the centre SOS speaker). To properly fix I need to remove the upper part of the dashboard. Has anybody seen any instructions? I've searched but can't find anything for the MK4.
Thanks.
I would get it done under warranty
i can pull up a parts diagram if needed, otherwise it's an hour's sub on Toyota-tech
edit. A pillar trims off - remove the 3 speaker grills and Speakers the rest is clips
Not after 6 months. Rattle appeared after 6 months.
Minimum 3 year warranty on a 2021 Yaris
But not on trim problems eg. rattles or vibrations
I'd been keen to know your progress. I have a rattle in similar location more closer to the left pillar.
Do so at your own risk.
The rattle appears to be coming from near the central speaker where the cover makes contact with the lower area. I've put some sticky foam/felt on the area and I'll let you know.
