Speedo/odometer change from kph to mph
JOHN K A
Can anyone recemmend a 'tool' that I can buy to change the speedo/odometer from kph to mph on Toyota hybrid cars?
I currently have an imported 2016 Toyota Corolla Axio hybrid ,right hand drive
Edited by FROSTYBALLS
Shouting removed
Not sure this would apply to your particular vehicle but I believe that there is usually a tric/hack that can be done to change the display from KPH to MPH without a special tool. That is unless the vehicle has an standard type analogue style speedo, which I doubt.
Try searching online for a means of doing just that, usually there's an option in the vehicles settings menu to change to KPH or MPH. If you have the owners handbook you should find it referenced in there.
