Sat nav on my 2017 Aygo is no longer coming up on the touchscreen. When I select connections on screen, Satnav is normally displayed.
Now it just searches for device(s) and times out. Has anyone experienced this problem or have a solution.
Thanks in advance.
Rob.
Do you have the X-Nav option, or do you use your smartphone?
If X-Nav then check the micro SD card in the glovebox is properly inserted.
If smartphone then has it had a software update?
I have the X-Nav Aygo PetrolDave.
Daughter is using the car today, so will try tomorrow and post result.
Thanks.
Rob.
