DRL bulb replacement?
clonzana
On one side only, the DRL LED "strips" aren't working. How easy of a replacement is it? Could I do it myself? Thanks
Do some more checks first,
If power feeding DLR bulb look for corrosion clean & cracked copper tracks resolder retest if ok borrow some nail varnish.
Cover solder & copper tracks with nail varnish give it time to dry.
Makes tracks waterproof & electrical insulates the rear of the circuit board
replace.
Other area to check No power feeding DLR bulb ignition on, fuse ok signal feeding DLR controller module if fitted.
Check clean earth contact.
