Hello. Rav 4 mk 3 2.2 Egr valve
Paul.falcor
Hello. I'm hoping the hive mind can help and I'm sure this subject has been done to death.
I've cleaned the Egr valve, replaced it, checked it's operation and I'm still getting the blocked Egr valve symptoms and check 4x4, check stabily, check something I can't remember warnings on the dash. Is there something I'm missing? Once car warms up it drives fine, just juddering / lacks power before it does and issue seems to be intermittent. Is there a sensor or something that might need a clean or replacement? Thanks
Hi Paul. Welcome. I'm sure someone will be able to help
