Tired of my Avensis T27
Zlappis
Have a 2010 model Avensis to use as a weekend/holiday car. Already have a small electric car that is used as an everyday car. I've only had problems with the Avensis recently. First I had to fix the steering axle, then I had to change the exhaust. On holiday the car suddenly went into emergency mode, so I took it in and had it serviced and the oil filter changed as it seemed that the oil filter was the problem - According to roadside assistance and the workshop. Recently the car went into emergency mode again. Then the error code showed that it was the lambda probe that had to be replaced. Handed it in and had it replaced. Today I was on my way home from work and during an overtaking the car went into emergency mode again. Connected to error code reader and got "fuel leak". Cleared the error code and was able to drive again. Could not find any leak. I'm so tired of the car now. Can't trust it. Any idea what could be wrong? Could it be an injector?
It is an Avensis T27 with a 2.0D engine.
Tbh it's hard 2 know what those problems are but all I can say the mechanic u got must have changed loads of things I'm guessing the car did not need .by chance would the egr and inlet manifold is clogged maybe as if it's a 2010 and never cleaned out .could maybe the problem
