Toyota Avensis T22 Sunroof
Mikey74
My 1998 Toyota Avensis T22 GLS 2.0l petrol.
My sunroof has stopped working, replaced the motor, switch checked fuses. The vanity light comes on but nothing happening with motor.
I have connected two wires to motor and both work. When all plugged in nothing works when using switch to tilt or slide.
Can anyone offer any ideas
Thanks.
Michael
Start from the Battery and confirm positive voltage at each point along the circuit.  Check the Battery, fuse, in and out of switch.  My best guess based on your description is a wiring issue between the fuse box and the switch.
