Some questions about the CD player
Olympian
I removed the original CD player today and there are 4 cables connecting to the CD player. Do anyone know what are the functions of these 4 cables??
Is this bolt important ? I lost one when i pull out the CD player.
thx....
Blue next to the white are the standard 10+6 - looks like you may have the optional bluetooth
White connector on its own is used for things like reverse signal and audio controls - Top black plug is for the tell-tale aka idiot lights
to fit a single din you need a facia adapter, to fit the double din you need a hutch, what are not cheap and are getting harder to find used
As for the bolt, if it's 6-8 mm long it's from the radio bracket or tell-tale
That bolt comes from here. It dropped to somewhere when i took the player off
