Toyota Prius 1.8 2014 front headlight balancer?
priusnoob
So I no longer have this car but my dad does. He says he needs a front headlight balancer. It's an imported 2014 car
I asked if he meant ballast instead? He said no. I can't see anything on eBay. Could anyone potentially help?
because your Prius is imported it might have different lights set up than the uk official cars. Best to have a look here , find your exact model and look for the part in question, then Google it and you may find sellers from other countries like Asia, Russia or Japan. 👍
https://japancars.ru/index.php?route=catalog/toyota
7 hours ago, TonyHSD said:
Thanks. Sadly they say "VIN code must contain 17 characters"  so they don't recognise it
Do you know of a UK equivalent part? I ask only because I find absolutely nothing when looking for a balancer, so I thought maybe that might help me look for others, and I could quote my VIN to those sellers. Well, not my VIN any more but my dad's
I think you can choose model by region ,
if you look here can you see what part do you need?
https://japancars.ru/index.php?route=catalog/toyota&mdf_id=239412&area=JP&cat=222130&blk_id=8101
I'm guessing that means they're an "ASSY"?
PM me a vin - headlight balancer ? do you mean a headlight level motor, level control or the dash dimmer control
85661-12020 lh or rh headlight level motor
So I asked my dad and he's said
"It's called balancer, not level control motor"
I'll PM you the VIN
You need to find out the actual issue/symptoms, has it failed an MOT ?
Looking up the frame number shows it's either
HID (it should have D3S or D4S on the headlight housing)
or
Led with a HB3 for high beam
Thanks. I don't believe it's failed the MOT tbf
Both types use a lighting control module - in the case of HID that would be a ballast mounted to the underside of the headlight
Thanks for that
