Faulty front screen washers - 10 reg
We have had the car for 7 years and replaced the front drivers side washer jet valve in September 2020 and it appears to have gone again.  Is this a known fault for IQ's at approx. £70.00 a pop?
What are you using for screenwash? Pre-mixed, concentrate diluted, washing up liquid diluted ......? If mixing your own solution, do you live in a hard water area?
Yes to hard water, could put a descaler through the system!
Probably be better off using pre-mixed screenwash in the summer, and concentrate with or without filtered water, depending on what % you need, in the winter.
Is the pump working ? There is a one way valve these block when you use cheap screenwash - no issues in 12+ years using Autoglym screenwash - The water around here is so hard it comes out of the tap wanting a fight
one way valve 85321-28020
  • Haha 2
I second the one way valve, I sell ten times more one way valves than washer jets
  • 10 months later...
  • 3 months later...
I realise this is an old topic but just had the same problem, diagnosed as the valve 85321 28020 and
stupidly just ordered the first one I found (ebay), fitted and tried it, all ok, 5 days later failure, not worth sending
back so have ordered another from a different supplier, hopefully will resolve it.
kind regards
Chris
  • 9 months later...
Well it seems that it hasn't, I fitted a new pump in Jan this year and now a dribble out of the passenger side and nothing out of the drivers side, I pulled off the in feed to the valve and water is coming out and I can hear the pump, so I stripped out the jets both sides and squirted silicon spray down them, it came out as a strong "mist" so they are I think cleaned, I then tried doing the same to the one way valve and spray came out of both exits so I put it all back together and nothing. So I'll order another valve 85321-28020
I am using pre-mixed screen wash
I've tried clicking on partsking, lindop toyota but the link doesn't seem to work🙄
kind regards
Chris
Send Parts-King a pm.
Just done that, I still can't get my head round the fact that I can squirt silicon spray through the valve but it still doesn't work !!
thanks and kind regards
Chris
Just got an original Toyota part, works perfectly, as a tip to anyone else needing this valve, don't buy a cheap one off the well known auction site,
stay above £15 ie. Toyotaparts and you'll be ok.
kind regards
Chris
