ST 205 water nozzles to clean the headlights.
jtanabodee
I've got ST205 for a year.  There are nozzles for water spray to clean the headlights.  There is a switch in the dashboard but it never works. Do you have any diagram how it works?  I have tried searching through internet and I found nothing.  I think it is very rare, nobody knows about that.
Do they work in conjunction with the windscreen washers? - but maybe only when the headlights are turned on? That's how they worked on my old Laguna.
I think it also doesn't work when I turn the headlight on.  I will check again, thanks.
