Hi all
on the EPC site the part number for the rear-wheel bearings is 42450-0F010
However when buying this part (tried two variants) the bolt holes to the drum do not align and are not the same size as the original piece.  Likewise the mounts for the brake drum and the wheels are incorrectly spaced.
This is the OEM number that is also listed on all the spare-parts sites.
the original piece has no markings on the bearing to help; but does have a marking on the ABS sensor (89544-02010) if that helps jog anyone's memory.
Does anyone know if there were alternative parts for the AUR10?  My VIN is NMTEA16R40R116859.  It's a LHD first registered in France.
In case useful I took the following measurements on the original piece:
on the mount to the hub:
bolt spacing (wide edge) 70mm
bolt spacing (narrow edge) 64mm
on the mount to the drum:
number of bolts to drum: 5
drum bolt spacing (centre to centre): 66mm
drum bolt size: looks like M12 (internal thread of 11.4mm)
external diameter: 140mm
thanks in advance!
Justin
