TOYOTA 2.2 D4D 2010
CiprianHazZ
Hello people, I also really need your help.
I have a toyota avensis d4d, 2.2 engine from 2010, I changed the hose from the intercooler because it was cracked and since then the car doesn't pull and consumes more.
I mention that there is no error on the tester from Toyota or on other testers. A lot of things were checked,
the throttle, the map, the map sensor, the gallery was cleaned, the egr, the turbine reconditioned, the turbine values reset .
what else can I try, please help me with an advice. anything is welcome. sorry for my english, i don't speak that well.
Maybe the injectors are playing up, been a few posts re this engine and age recently.
Also wouldn't show up as a fault code if just on their way out Ciprian.
