Filled my o7.fuel gage staying on full.
Pull the sender unit check the ohms on the swing should be 10-100 ohm
I'll go try
Is the car new to you ? once the tank is brimmed, the gauge may not drop a bar for 130 miles or so
Disconnect fuel sender unit wire make sure its not going to earth out gage will be around zero now.
If not it may be the power supply to the gage at fault.
Taken wires off still showing full.taken fuse out then back in still showing full took Battery on and on still showing full.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
