Wing mirror
roger_37
Was out driving when I hit a branch on the passenger side and broke the glass wing mirror indicator  can this be replaced individually or is it whole back to be replaced?
Edited by roger_37
Yes, you can change out the indicator unit. Fairly easy DIY job. I (and some others on here) have swopped the OEM indicators to sequential LEDs (I think around £30 for the pair from memory). While you're in there, you can easily upgrade the puddle lamps to better LED bulbs too, which is a worthwhile upgrade if your model hasn't got them already.
anyone have a wing mirror diagram so i can see how to fix this, thanks
Don’t have a diagram but try YouTube and search fitting LED repeater lights. This will show how to take the covers off and fit the lights. I used this when I changed my repeaters to LED and the puddle lights at the same time.
so are they not led the indicator on my motor as i dont know which ones to get thanks
I just popped the back cover off with my fingers starting at the outside edge. Just be careful with the tabs on the inside edge, they are quite thin and there the ones that will snap if you're not careful.
I can't say for sure, but see yours is a 2021 model which I didn't think had LED lights but mines a PHEV so some differences in spec. You can chose whatever you want, the original and LED are the same fitment, but if changing, you'll obviously need to do both to match. The sweeping LED ones do look good though.
