Yaris MK3 pollen filter airflow direction
v1nny
Hi all. I've got a 2012 Yaris MK3, and it's service time. I ordered a replacement pollen filter as it looked easy to do myself. On the plastic bracket piece, the 'UP' arrow was pointing up. Fair enough. But the existing filter had the 'Airflow' pointing downwards 😕
Just want to double check it was installed correctly before, and I should follow that? Here's a picture of me holding the new one. Should it flipped so the 'Airflow' is pointing downwards?
Many thanks for reading 😀
26 minutes ago, flash22 said:
air is pulled in from the top, so air flow is down
Thanks flash22. I've just installed the filter with the airflow arrow pointing down as advised. Kind regards
That's going to be confusing... I'll have to double-check whether the arrow is an orientation arrow or a air-flow direction arrow when I start having to change mine myself!! :laugh:
Is it obvious which side is the 'in'-side and which side is the 'out'-side on the filter, or does it look the same on both sides??
This is one thing that was good about the Mk1 - It had a carrier so it was physically impossible to install it the filter the wrong way! It also sealed the filter better - The current design I can see air bypassing the filter around the sides as there's no seal or anything...
Usually it will be an airflow direction.
These filters are often generic and may be used in different cars and indeed other equipment, so the air could be flowing up, down, sideways or at an angle. So an 'up' arrow makes no sense.
Of course a typical mechanic will think it's 'up' 🤪
Arow down if it says airflow, arrow up if it says up. My MK3 had the filter installed the wrong way (arrow and UP printed on it pointing down) by Toyota main dealer. Air con improved no end since I fitted a new filter the correct way round.
  • Like 3
Yes, if it actually says up, probably on a Toyota part where the application is defined, then do that.
For generic parts if there is no text, just the arrow, it should be airflow. But I'm sure some will be vague or wrong.
The blower motor sucks air in the top pulls into the centre of the squirrel cage, it is then blown out to the edges and force into the heater box
the speed control  "resistor" is in the air flow before it goes into the heater box to aid cooling
This filter should be placed upside down, with letters pointing downwards. Here it’s how should be installed. My filter is different make and arrows match installation orientation and letters. 👍
THAT IS NOT UPSIDE DOWN, THAT IS CORRECT FOR THE AIRFLOW!
Yes, I know I had caps lock on!
I meant with letters upside down in his particular case and filter. Anyway, it’s so easy and nothing complicated. 👍
But the letters aren't upside down ...
Oh, hang on. Which picture are you talking about?
Edited by MikeSh
Clarification?
Air flow arrows or an UP arrow isn't needed anyway, but obviously help (certainly for some Toyota "technicians"!), the end of the filter medium pleats are on top/up.
As in Tony's pic.. Or incorrectly in the Borg & Beck variant, as already pointed out in previous posts.
I don't know what you mean by that. I haven't examined one minutely, but they look the same to me both sides.
I think my Mk4's is the same, although I haven't looked at it properly, just to check if they'd changed it! If it weren't for the writing I don't think I'd be able to tell one side from the other, unlike the Mk1's filter which was completely different on both sides and would only go into the carrier one way.
