just check the filter and the resistance of the ocv
have you tried starting the car on easy start ???
you have a spark so it is neither the crank nor the cam sensor
remove the Aux Belt and see if it starts if it does do not run it for too long
OK I'll check the filter if it comes out and the resistance of the valve, do I just spray easy start down the throttle body while someone cranks it do I give it throttle at the same time and what am I looking out for if it starts when aux belt is off.
easy start - crank it over, spray it, it may help if the throttle is pressed but not needed
Aux belt - that will rule out any issues with the water pump, AC or alternator
Cheers I'll give that a try tomorrow.
Does the OCV filter come out in one piece
OCV looks to be OK according to my reading is it still worth taking the filter out
Managed to get the this off are the filters stuck inside
I've got some carb cleaner can I use that if not I'll buy some easy start
I've checked OCV seems OK, easy start sprayed down throttle body the only thing I couldn't do was remove the OCV filter, the bolt come off no problem but didn't no how to get filter out, if that was clogged up would that affect car not starting.
what did the car do on easy start?
OCV filter, yes its down that hole use a pair of long nose pliers or a bit of rubber pipe
Easy start made no difference, had a mechanic out today and his diagnostic scanner and wouldn't communicate with the car it says ignition needs to be on he can't look a live data
Ignition was on as well
well that is why you have no codes, first off check you have power to the OBD2 port
Pin 16 - 12v
Pin 4 - Chassis ground
ignore the TS marking
just had a look back over this thread to recap
I believe the issue is the original ACC problem you had, put the key in the ignition and push up as you turn the key
Pin 16 - 12v
It has power because my basic scanner powers up and the mechanic has better piece of kit it was the size of ipad with a cable plugged in the obd port, he said he's scanner should able to identify any ECU's and read the car's vin number but there's nothing coming up on the scanner apart from the car's voltage
That was sorted it was fuse number 11 15amp at the left side of the speedo that's been checked and is all good I've also tried putting the key and push it up as I turn the key
if the acc 12v is dropping during crank or not feeding the ECU it will cause the ECU not to turn on properly
unless you have something pulling down the network like faulty ABS or EPS
checking all the fuses may not be a bad idea making sure the sockets are tight and clean and unplugging and replugging the wiring to the back of the cluster
have you tried to get the ecu to flash any codes out by linking pins 4 and 13 of the obd2 port
The 12v supply is OK on the acc and ig when cranking I've also had pin 4 and 13 linked for 35 minutes, I'll take cluster out and check connections and fuses, thanks for the advice Bob.
4 and 13 should flash back any codes, link it turn the ignition on you will get 1 long flash then count the flashes it will give you the first digit then pause and flash the 2nd digit it will carry on if other codes are stored or just repeat the first 2 digit code
i think you need to pin down the reason you can't talk to the ecu
OK thanks I'll give that ago, what flashes? Yeah have to see why the scanners can't talk to the ecu think the mechanic is going to speak to someone at Toyota who he knows
You've been very helpful Bob, I'll let you know how I get on
you can try pulling the eps and/or the abs fuses and see if that makes any difference
Hi there,first time I've had the chance to look at the car since my last post, I linked 4 and 13 for flash back codes the 2 tonic gearbox light flashed 9 short pause then 5 long pause then 10 short pause then 2 (repeat) the abs light flashed 3 short pause then 8 long pause then 3 short pause then 9 (repeat) the engine warning light was just permanently on I don't know if the gearbox and abs warning flashing like that mean anything.
do your brake lights work ?? please refresh my mind to the issue you have now, it started with a crank no start - what is the current issue and has the car been sitting a long period
check and confirm voltage by removing/replacing the Stop and EFI no.2 fuses
