Air con, Cold driver side only
JasonT27
I have a 2013 t27 avensis 2.0 diesel. My air con only seems to be cool on driver side but the air isn’t conditioned on passenger side . Any advice on this ?
Is it dual zone climate control you need to double check your settings.
6 minutes ago, JasonT27 said:
Yes it’s dual, both are set to low
Well in this case you might have issues with flaps actuators on one side and they keep air flow restrictions or disconnected air duct. You will need to get behind ( under ) the dashboard and further investigate. 👍
Before you rip things open, go to your car repair guy and ask them to refill your airco.
My car once had the same. It was fixed after a refill
That's a good shout actually, you reminded me that my colleague had a similar problem several months ago and it also just needed the gas topping up.
When low on gas the car ac tent to send cold air mostly to the centre of dashboard and both sides are basically not as cold. Top up gas and change of pollen filter are the first steps indeed 👌👍
