Avensis 2011 saloon seatbelt chime?
Waqs
Hi everyone,
Hope we all ok.
Does anybody know how to disable the seatbelt chime on the MK3 Toyota Avensis 2011? I knew how to do this in the MK2 2007 but it does not work on the newer ones.
It can be done using Techstream on a laptop.  The warning light stays on tho.
Or you could just use seat belt extender...
I also have another Toyota Avensis 2011 Saloon and since I bought it, the seat Belt Chime has never been active and no warning lights are on. Therefore, I assumed there must be some formula or feature to turn it off just like the MK2 (set the ignition to ODO, turn off ignition, turned back on and keep hold of ODO metre button for 10seconds and plug seatbelt in and then it should give you an option "b-off or b-on").
On 8/11/2022 at 7:56 PM, Waqs said:
Hi everyone,
Hope we all ok.
i disabled mine threw techstream it was really annoying plus it went threw the mot turned off the light flashes on the dash but no annoying bing
