Mk4 aftermarket radio adapter/fascia
flash22
While trawling the Connects2 website, i come across the radio adapter for the Mk4 Yaris, what allows you to fit an aftermarket modular display or one of the many L shaped single din
https://connects2.com/Product/ProductItem/CT237MZ01
It may be useful to someone
Oooh nice, those things are usually a right *$£&% to find for a car this new!
I wonder if they're going to do the adaptor harness for the steering controls too... (Unless one of their existing ones is already compatible...?)
Controls are the standard Toyota type, the radios use the standard Toyota 10+6 for Speakers and power and a 28 pin for anything else
You will loose all the car features that the head unit provides.
Most of the functions can be done via the dash as these cars age and units fail they will get replaced
A lot of after market head units seem to provide access to at least some of the built-in car functions, although I don't know how...!
It would be interesting to see if you could still e.g. disable the Smart Entry system with a third-party headunit, as that is one of several functions that you can only configure from the headunit and not the steering wheel MID.
