2022 HILUX Issues
CJL HILUX
I have owned 7 Hilux's in over 30 years and have loved them all and wouldn't dream of driving any other make, 5 were second hand and the last 2 brand new. The latest one is a 2022 Invincible x 2.8 manual which I picked up at the end of March and has just over 4000 miles to date. Around 2 months ago I started to notice a "flat spot" between tickover and 1600 rpm, it feels like I am towing something really heavy and has a sort of pulsing, I also notice it on steep hills where I back off towards the top and it feels like I've hit the brakes. If it was an old petrol engine with a carburetor I would say the pilot jet was blocked. As soon as I pass 1600 rpm she flies. I took it in to my dealership and they came for a test drive and then put it on diagnostics and said all was fine and I should knock it down a gear or 2 and rev it harder! I said I have owned 7 of them and never experienced anything as gutless at low revs as this one. I was hoping this 2.8 would have loads of torque and not need reving hard especially with the price of fuel. My last truck was a 2016 and I still owned it until recently and when I occasionally took it out my 1st reaction was !Removed! HELL this is lively when pulling away. The mechanic suggested a possible blocked fuel filter but didn't offer to change it. I do remember some of my older trucks feeling like they had a new lease of life when a new filter was fitted. I always fuel up at busy filling stations but could possibly have picked up some dirty diesel?
Has anyone experienced anything similar?
ps. When I 1st lifted my Wiper Blades to clean the windscreen I found a 3inch windscreen repair in the centre like so many others have pointed out, when I showed it to the salesman and mechanic they said, "don't know anything about that"
Chris
  • Sad 1
Maybe your lack of power is down to turbo lag.
I woodent expect replacing a fuel filter at just 4000 miles
If its a fuel filter your power will die when reving it hard going up a hill.
It cut out and after a minute or two it will restart without showing any error codes.
Many thanks Derek,
I was describing it to a friend a few weeks ago and his granddaughters vw golf (I think) had turbo lag, took the garage ages to work out the problem and it did sound very similar to mine.
  • 11 months later...
That "flat spot" issue you're describing sounds really annoying, and I can't believe the dealership wasn't more helpful. I had a somewhat similar hiccup with my own Hilux, but a fuel filter change did the trick.
Can't help but share this with you
 I recently installed the 3" Lift kit Hilux N80 on my 4x4. Man, it made my rig an unstoppable offroad machine with its new 3-way damping adjustment system. It's more comfortable too.
