Hi all I have a estima 2.4 hybrid 2015 model, everything was working fine, however out of no where the right turn signal stop working, the left works fine, the hazards both work fine, however the right has just stopped working
My first idea would be to check the indicator stalk. Does it latch into place both ways?
I've read similar posts on the net with all makes of car with this problem. A possible issue is that the contacts within the stalk, oxidize and then electricity can't flow to complete the circuit.
With the key in the off position, try gently operating the stalk to the right indicator position, then off again. Do this dozens of times.
See if this action clears the oxidation and allows it to work again.
This is only clutching at straws and may not be the actual issue, but worth a try.
The right stalk click into place and when you turn right it clicks back,
The only time this happend to me was with a lease car and garage replaced the stork it just plug in
but the real problem was a loose wire rhat was once soldered on the stork comming loose.
Garage returnd old part to me and my curiosity took over.
So it may pay you to look closer with a flashlight after removing a cover or two if you have to.
Will give that a go,
Tried moving it up and down whilst car was off still no joy left in down in right turn overnight see if that helped still no joy
Seems to be working again, checked all the wiring everything looked fine was ready to take steering wheel off and take the indicator stalk off, but before I took the stalk off thought I'd give it another go and it just started working, had the car Battery disconnected the whole time, random possible something to do with the above suggestion of the electrodes etc
Posted (edited)
Edited by Paulscarbs
  • 4 months later...
Out of nowhere this started working, has worked for a few months and now stopped working again
If the hazards work, it's a stalk problem
2 options on a 2015 AHR20
84140-42070
84140-42080 (front fog lights)
Yeh I think it must be the stork, any idea if there is a video about on how to replace it
Battery disconnected, remove the airbag, remove the wheel, remove the upper and lower cowl, remove the clockspring
it's a fairly standard job
