Hello toyota owner fellows,
I have two toyotas (Auris and Corolla). Corolla is from year 2002, E12, 2.0 D4D with 66 kW engine (manufactured in UK)
It is time to change rear splash panels and to my big rusprise I'm not able to find suitable replacement.
I can only find splash panels that fits 258 mm rear brake discs, but my discs are 279 mm. I have tried on eBay and many other web pages I could google it.
Does anybody know what are the dimensions (diameter) of splash panels for 279 mm rear disks?
Thank you!
The OEMs are 46504-02030 and 46503-02030.
  • 1 year later...
I can only find splash panels that fits 258 mm rear brake discs, but my discs are 279 mm. I have tried on ebay and many other web pages I could google it.
Thank you!
Hi
Did you ever find a solution to this , I am currently in the same problem
I've had the wrong ones installed only to discover ther were wrong when I went to put caliper mounting bracket back on
Cheers
Brian
pm me your vin/frame No. and i will look it up
Hi flash22
See the difference in the holes for brackets
New plates are the correct aftermarket parts with the same Toyota part number you will find online
Toyota genuine parts 440 each side 🙄
Hi Flash22
Sorry new to site so didn't actually pm you the stuff like I taught
