Removing excess oil from dipstick hole in Toyota Auris engine
Avtandil
Hi. Does anyone know what size hose i need to remove excess oil from dipstick hole in Toyota Auris engine?
thank you
Best to measure the dipstick tube and buy accordingly. I think size of 5-6mm  diameter will be fine. There are some syringe sets including tubes in Amazon on good prices .
Regards
I have one of these extractor pumps:-
https://www.amazon.co.uk/Pela-6000-Oil-Pump-Extraction/dp/B002EJ2GUC
The pipe on this that goes into the dipstick hole, as TonyHSD says, is 5.6mm wide.  I know, because I've just measured it. I've yet to try a car the pipe didn't fit into.
I can third the above. I have the Sealey version of that to which Gerg links.
An Amazon Warehouse purchase, damaged box only, at a ridiculously reduced price.
A black reinforced pipe 5.6/7mm outside diameter. Works very well with warm, not hot oil. A slight own goal because it's still necessary to crawl on the floor to change the filter!:laugh: Depending on car, of course.
Should fit into most dipstick tubes.
https://www.amazon.co.uk/dp/B08837GVBN/ref=syn_sd_onsite_desktop_190?ie=UTF8&psc=1&pd_rd_plhdr=t
I have this one for myself from lidl but never used to date, previously I had to take out 1ltr of engine oil from a used car I had, the engine was running nice a sweet but someone had just put a lot more oil or additives in. I had to drive like that from Oxford to London but then I removed the excess oil. I used this syringe 200ml and tube and lots of pumps
Up to 0.5 L overfill from max level is fine. It is about 1 cm above the max marking. More than that, we should drain or suck them. I usually fill it at Max level with filter change with  4.2L oil. 4.5 L will be slightly overfill.
