DRL front ligths... It's done...💪💪
Sérgio Alves
Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbol';">Hello,
This is the end result... with your help
#tarquin. Many Thanks
  • Like 6
Hi Sergio,
First of all nice work.
Where did you buy the lamps and how does it work for wiring?
Thank you
They look cool, I've always thought about doing DRL's but have got scared about the wiring because of the auto lights.
Like the way you've fitted them to the headlights, i always thought it would have to be fog light replacements or small aftermarket ones in the "grille"
On 9/1/2022 at 9:35 AM, Sérgio Alves said:
I will make a full DIY for you... ok?
Ok thank you
Vou tentar explicar como fiz para colocar as luzes dos mínimos como drl.
Material:
Lâmpada LED W16W Osram LEDriving SL 12V 2,9W Conjunto 2 pcs. Luz branca 6000K
Referência: 921DWP-02B
Mandei vir do site: www.leonleds.com
E um repartidor de fusiveis ( ver imagem) comprei na Norauto
Em primeiro lugar separei (cortei) os fios da ligação original do carro para fazer um sistema autónomo. Passei um cabo de 2 fios de uma ótica à outra.
Colocar o repartidor de fusiveis na box que se encontra do lado direito no compartimento do motor. Daqui fui buscar a energia (+) para quando ligar a ignição ligar as lâmpadas.
E o fio da massa (-) basta conectar ao chassi do carro.
Agora irei montar um kit/ módulo de forma que quando ligar os médios as lâmpadas do mínimos fiquem com 50% da intensidade ( fica a funcionar como os drl normalmente funcionam).
Site de  compra: www.oscarparts.com
I'll try to explain how I did to put the lights of the minimum so drl.
Material: LED lamp W16W Osram LEDriving SL 12V 2.9W Set 2 pcs. White light 6000K Reference: 921DWP-02B I had it come from the site: www.leonleds.com And a fuse splitter (see image) bought in Norauto
Firstly I separated (cut) the wires from the original connection of the car to make an autonomous system.
I passed a two-wire cable from one optical to the other. Place the fuse splitter in the box on the right side of the engine compartment.
From here I went to get the power (+) for when you turn on the ignition turn on the lamps. And the mass wire (-) just connect to the car chassis.
Now I will assemble a kit / module so that when you turn on the mediums the minimum lamps are 50% of the intensity (it is working as the drl normally work).
Buying site: www.oscarparts.com
