Auto Lock upgrades
MiloAAA
Hi all
Back again.
Have learned a lot since getting my new yaris cross luna but...
Is there a way to upgrade the software on the Luna so I can activate the autolock system.
In my model (the Luna) there is no autolock system.  We have to manually lock the doors.
Also the car stays open if you forget to touch the handles or press the lock key on your remote.
Any way to solve this.
Thanks all.
  • 1 year later...
On 8/26/2022 at 4:04 PM, MiloAAA said:
Hi all
Back again.
Thanks all.
The only way to find out is by getting an OBD2 bluetooth scanner from Veepeek and the Carista app. That will allow you to go into some extra menus and see what is available to change/customize.
42 minutes ago, MiloAAA said:
Anyone know if the OBD2 Bluetooth scanner works?
Not as far as I know. Calistra app def not an option on version I have downloaded.  Believe the hardware needed isn't fitted as standard so can't be switched on by software.
