Uneven idle loss of power maybe VVT solenoid
ianlea
On a long hot drive 300 miles just before I got there to collect my stranded daughter under load the warning light came on went off not under load but the last 5 miles was not sure if we would make it.
2000 VVTi CELICA 190,000
Any advice welcome but specifically
COST
POSSIBILE PROBLEMS
IS IT WORTH FIXING
Which warning light?.
A VVTi that has has covered 190k has done very, very well. Many have died having suffered the "death rattle" due to the inherent oil burning issue.
it has done well and yes it burns a lot of oil, I am going to take it to a Toyota specialist to see what it the problem is, the AA sent me this.
Patrol found the following fault code/s:System : Global OBD II - 000 / Global OBD II Status :P1300 - Unknown fault. Error Message : . Fault stored. Status :P1305 - Unknown fault. Error Message : . Fault stored. Status :P1310 - Unknown fault. Error Message : . Fault stored. Status :P1315 - Unknown fault. Error Message : . Fault stored.We have arranged for a recovery of your vehicle.Engine Oil Level Ok. Coolant Level Ok.
hanks for the information regarding the codes, I only found the AA report last week and did not know I could look up the codes
Changed the plugs much better cylinder 4 burning oil next step change the injector
