Airbag warning light issue
marcel01
Hey everyone, I hope this the right place to post this kinda query.
I have a 2008 aygo with an airbag warning that goes on and off randomly, at first I thought it could've been moisture related as a few times it happened right after rain. I got a basic diagnostic done and they couldn't find the source of the issue, they only told me it's an error code B1826 "BFS front side airbag igniter circuit. Open circuit.".
I didn't have any other ideas as to what is causing that until today, when I closed (or rather smashed) the glove box the warning came on again almost instantly. I suspect there is an issue with some wiring/connectors under the dash/behind glovebox somewhere ? I tried opening small lid in the glovebox, only bunch of random wires there, all looking fine, I couldn't see any connectors there though (apparently there's supposed to be one easily accessible).
I'd appreciate hearing any suggestions/ideas 🙂
Check the connections under the passenger seat before doing anything more complex\expensive.
B1826
  • Center airbag sensor assembly receives open circuit signal in side squib (P seat side) circuit for 2 seconds
  • Side squib (P seat side) malfunction
  • Center airbag sensor assembly malfunction
  • Floor wire
  • Front seat airbag assembly (P seat side)
check the yellow connector under the passenger seat, OBD codes have generic meaning, B codes are manufacturer specific - above is the code definition for the Aygo KGB10 2005-10
The centre airbag sensor lives under the centre console, in front of the gearstick
Thanks for the replies, I've already checked the connector under the passenger seat a few days ago but I'll give it another try. Are there any other relatively easily accessible connectors somewhere in the front part of the car that I can check ? I'm pretty sure something there must be loose since one of the times the light came on after slamming the glove box door
Remove the centre console, 1 bolt in the cup holder the rest is clips IIRC
