Yaris MK3 hybrid - Instrument cluster upgrade
reinoso
Hello all,
I wonder if it would be possible to upgrade the MK3 1st restyling cluster to the 2nd restyling one. It seems that they have the same back connectors.
Imagen 1 - Toyota Yaris Híbrido km/h Tacho Cuadro De Instrumentos Velocímetro Speedo 83800-0UC90
To:
Imagen 1 - 2019 Toyota Yaris MK3 1.5 híbrido gasolina racimo del instrumento Speedo 83800-F5451
Thank you!
Oh yes it can be done but needs to be programmed
mine is fully working the water temp and digital speedo are a good upgrade
don't forget you need the steering wheel controls and to add 2 wires
Yeah, that is exactly what I was searching for. Congrats for the project.
Do you think I could do the mileage correction through OBD? I have a J2534 interface and maybe it can be done with a paid access to toyota-tech and techstream?
About the steering controls ... mine has TSS and the LDA button at the right side:
So, will I lose this control if I replace with the new one?
Thanks!
There are a few different types of controls - you can do it over obd2, but not with techstream
standard menu controls 2 of the types
tbh not seen many pre 2nd facelifts mk3's with tss (2014-2017) - its a case of plug the new style dash in and see what works or what errors you get
Edit. IIRC instead of the button, the LDA is in the menu on the later cars
