Rear disc T sport
TJF
Hi can anyone help with a little problem I hv with my rear brakes IV renewed everything on the back hub bearing s sensors backing plates disc's pads calliper s drum shoes and the shoes are rubbing even though i hv no hand brake are there different sizes of disc for the back ?
Were the shoes chamfered on the leading edge ? did you clean or replace the springs and fixings ?
Shoes.
2zz uses 172mm x 32mm
1zz uses 200mm x 32mm (Akebono)
did you transfer the handbrake leaver over ?
