Oil Filter tool
Gary Ball
That looks right. But you really need to check on the filter that's currently installed in your car. The key information for that removal tool is: 14 Flutes 64.5mm
21 minutes ago, TonyHSD said:
This is the right tool indeed. 👍
Thanks Tony
Look right for me
Draper filter socket 64.5mm 14F-6S part number
DRAPER Stock No 29130
Torque setting is 25Nm +or-5Nm
On 9/1/2022 at 9:47 AM, Gary Ball said:
 HI All
I require a tool to remove the oil filter on my avensis 1.8 TR petrol. Any recommendations?
I have found this one but not sure if its the correct one? https://www.ebay.co.uk/itm/403588850832
Cheers
I have the very same tool. Here is my post.
Hi Conrad.
I had seen your post and tried to match the filter socket to yours
Its arrived and fits perfect. Avensis T27 1.8 TR Petrol
Thanks All
On 9/3/2022 at 9:09 AM, Gary Ball said:
Hi Conrad.
Thanks All
It can be difficult to compare photographs, and rely on the sellers description. In the end, you have the correct tool. 👍
