Interior lights fuse.
Hi guys,
The interior foot well lights that operate when the door is opened and the C-HR projection lights have stopped working (2019 reg C-HR). I suspect the fuse has blown, why is another question of course, but can anyone point me to the fuse and it's location that would protect this circuit?
Thanks in advance.
Charles
Hi the fuse box is located behind the glove box
Thanks I guessed that but which fuse is it?
Fuse box look under air con unit behind plastic cover.
Thanks Derek, surprisingly the fuse box is easy to get to, but I need to know which particular fuse protects that circuit. The legend on each fuse is pretty much indeciferable gobbledegook.
My best bet is your fuse is marked up as cigar /cigarette lighter covers your interior lights.
No, cigar lighter works.
  • 7 months later...
Hi, I have the same problem, no puddle light or ambient lighting and interior lights don't light up when door opened and wondered if you had located the fuse?
I had inadvertently turned off the lights in the settings.
For reference, the interior light is caled the Dome Light in Japanese parlance. So just look for the Dome fuse.
First one on the left as you look under, red micro fuse 10 amp
