Toyota Celica 2003 back subframe rust
Ryan Buttle
Hi all, I’m relatively new to this type of car and how it works, I’ve just got my crocs and it has a bit of rusting underneath the car where the subframe on the back is located, just need a opinion on what I should do as I don’t know how much it’ll cost to repair or if any garages will take it on, I’ve also had the heat shield come off but that’s a easy fix I’m assuming !
cheers
Ryan
  • 5 weeks later...
On 9/4/2022 at 3:19 PM, Ryan Buttle said:
...just need an opinion on what I should do...
Remove subframe, sandblast, epoxy primer & paint and then refit.
If it is too badly rusted, you can buy a new one from GT4-Play.
TCB in Callington are also a good source of parts for the later Generations.
