Can anyone please tell me how to change settings for Corolla hatch 2019 non-smart key to unlock all doors when pressing the unlock button on remote? Mine only unlocks the driver side door.
Thanks in advance
Ajith.
Press set up on multi media left hand menu scroll down to vehicle and press you will then see vehicle customisation select this then select doors to unlock make sure all doors are selected to unlock with one press of remote ( assuming it’s the same as uk spec)
Thank you for your reply. Unfortunately, doors option is not available in the vehicle customization menu.
Have you pressed the unlock button on the remote key twice ?. That should unlock all the doors including the hatch.
As Rosgoe said in the previous post this option should be available from the navigation screen but maybe not in your country. This should be a simple change for a dealer to do and possibly without charging you - I have known dealers trust the apprentices to do such an easy task.
The OP is in New Zealand, so the car may differ from UK built models. The multimedia unit will be different.
Thank you Guys for all your suggestions. I ended up taking my car to the dealer and they confirmed that pressing the unlock button twice is the way to do it and this can only be changed in the car computer. It is strange this model doesn't have this option in the console menu.
