2017 Radio not Compatible with 2013 Verso
5 minutes ago, flash22 said:
The radio isn't seeing the reverse signal then
do you have a pin 2 on the 28 pin on the car plug ?
Yes there's already a wire in it
Do your reverse lights work ? You should get 12V on pin 2 when in reverse (ignition on)
Reverse lights do come on
Does this mean more tinkering with the wires?
No, just asking
1 minute ago, flash22 said:
No, just asking
Do you know how I can get this trigger the camera? Again I really appreciate your input on this. I wouldn't know where to start 👍
The radio needs a reverse signal to tell it is in reverse to switch the display in turn this sends 6v to the camera, you have the wiring in place
so do your reverse light(s) work ????
Yes they 100% work. I got the wife to stand behind the car to check
You need to confirm you have 12v on pin 2 when in reverse
Sorry, how do I do that?
With a multimeter or a 12v test light, both are cheap and easily available
I'll have a look tomorrow to find one. Ive already spent £30 on top to try to get this sorted.
I think I have one them screwdriver things that light up. Where would I stick it whilst in reverse? In the harness that's already in the car. What would I potentially need to do? I take it more tinkering. Just tested my current head unit and camera still working.
test light - clip the negative to something metal  place the tip on pin 2 put the car in reverse, i will double-check the diagrams to make sure i haven't missed anything - if the old unit works it must be ok
Ok I bought a multimeter. Powered the car on touched the negative to metal and red into the pin 2. This is the reading. This was the same reading when put into reverse.
set the meter to 20 or 200 volts
I did after to 20 and it was 0.022
Sorry, I did it again, in reverse, on 20 and 200......
Ok you have voltage in reverse, i will have a look at the diagrams
Having dug through all the diagrams, i can't see what the problem is
what is the model number of the new radio ? Do you know what software it is running ??
This is what the label says on the radio. I'll have to plug the thing in sometime to get the software version. I've noticed on the forums that there are other owners with the same issue, upgrading from Touch to Touch 2 and with the same 16pin Vs 24pin issue. No one's seemed to have found a solution.
86140-0F110
16 - 24 pin isn't an issue
if you just have the 28 pin plugged in, when you put it in reverse the radio should show REV on, in the hidden service menu - testing with a multimeter shows you have Battery voltage on pin 2 in reverse
do you have a pic of the 24 pin plug you are using
2 hours ago, flash22 said:
86140-0F110
if you just have the 28 pin plugged in, when you put it in reverse the radio should show REV on, in the hidden service menu - testing with a multimeter shows you have battery voltage on pin 2 in reverse
Hi, yeah I did this when asked and it definitely showed Rev - Off.
I just done the same test with my current, without the 16pin camera and REV switches to ON when in reverse.
Please see the 24pin I'm using which is I've connected the cables as suggested.
Ive also went into Diagnostics on the new radio and found these. Some of these codes are present on the current radio.
Oh and the software version on the new radio is 01015B
B157D is no dab aerial
B1550 dab error
B1579 is no mic
from info i have gathered, the later radios get the reverse signal from the can bus, usually pin 2 can override this but not in this case - i will look into a work around
B1550 dab error
B1579 is no mic
That's great, many thanks 👍
Maybe worth a shot, do a INIT reset hold setup and turn the headlights on and off 3 times, this brings up a red sytem check mode with a INIT button, iirc press and hold for a few seconds and release, then cycle the key
