Playing music through my radio
Python285
Hello. I’m new to cars and this is my first car upon turning 18. I’ve been wanting to connect my phone and play music through the radio, but there is no usb plug anywhere. The radio model is apparently 58826. Is there anything i can do? Is there a plug at the back of the radio?
The radio looks exactly like the image attached. I’m really hoping you can help me, thanks
If there's no 3.5mm aux or usb socket, you will likely need to buy a module to plug into the back of the headunit.
In my Mk1 Yaris I had a box that provided 3.5mm, USB and SD card slot that plugged into the CD changer port at the back of the headunit and pretended to be a CD changer.
The tricky bit will be finding out what your headunit is compatible with!
