Posted (edited)
Hello Friends
After an Catalytic converter change, my car wont start, Replaced with the old Converter and lambdasonde, still the same
It cranks,
It fire up the spark plugs
tried with both keys
no error codes
Get 12 v on the Fuel Pump but no Amp, Tried to wire it up with a ligth bulb, no light.
Checked fuses,
Any suggestions?
Edited by Abesen86
added Tried with both keys
All you have changed is the convertor, did you disconnect the Battery at all ??
What did you remove to take the cat out of the car ??
Do the lights and blower motor still work ??
The front Bumper is taken off, The batteri was on and connected, At the moment i have pulled the fuse box and the wiring from fusebox to ECU, for inspection for broken wires , so i cant at the moment double check about the Light and the blower motor, but there was interior Light
If you have only been in one area, i see no reason to be anywhere near the ecu or fuse box, you're just chasing ghosts that don't exist
only thing that springs to mind is you have tugged on the loom, and it popped/broke a plug check the cam sensor and the CTS
