Wheels And Springs
Dougs
Ok haven't even got the car yet and already thinking about what to do to it :D
Id like to lower it and change the wheels but got a couple of Qs
SPRINGS
From what ive read the tte spring seem to be the most used on here or are there any others i should look at aswell
WHEELS
Will 17" fit straight on or will the arches need folding if the cars been lowered if so i'll just go with 16"
TTEs are he yaris modders choice although be aware they are only rebadged Eibachs
at the end of the day all springs are as good (bar some are a little stiffer than others) as each other so brand name is not really an issue
one thing the yaris requires without fail though is lowering!!!
17s you may get some scrubbing if you hit pot holes or go round corners fast, so arch mods are necessary
16's should be ok although its the width of the wheels you have to be more concerned about and the offset
17" will need arch work if your going to lower it, and they will make the car sit higher aswel, 16's do seem like the best option apart from the price of them they are about as pricey as 17's,
I find the problem with 16's is that all the popular wheel styles do not come in that size. They are always 15' and 17's :angry:
I've got my car lowered onto 17's and don't really have a problem unless i go like an idiot at a speed bump :unsure:
What tyres and offset you using pete? Also how much is it lowered??
:thumbsup:
Matt
