code 2118, no start 2007 Yaris
ThisLilYaris
Specifically a code p2118 on a family members 2007 Yaris 1.5L (02/07 build date, just noticed this is a UK site, we're in NA/USA)
Story- My aunt and uncle were sold a Reverse polarity Battery as a replacement (and didn't notice it was wrong).  When my uncle installed it they noticed something wasn't right. Thats when they called me. Car started, ran, and drove completely fine for >200k miles before this Battery swap mixup.
 They exchanged the Battery with the proper one, then I replaced the battery + fusible link which was blown, and I've checked all fuses (pretty sure I didn't miss any).
I dont have access to alldata or a toyota techscan tool, just a obd2 bluetooth scanner and Torque app.
I do not believe I hear the fuel pump power on/prime with key, the car cranks but will not run. The dome light is also not working.
Did notice I'm not getting 12V into the ETCS fuse, and I'm not getting the 12V into the 'Dome' fuse (fuse block in front of the battery)
Anyone know what is upstream of these two fuses? or any other suggestion?
I learned of the immobilizer reset and tried that with no different results.
I have a feeling its a blown circuit in the ecm. I'm trying to find some info to confirm that thought, so I've been piecing together info for which terminals on the ecm I should be checking, and really any other advice, I'm getting closer but nothing yet. (Update- I ordered a used numbers matching ecm, cheap on ebay) , did the immobilizer reset and still same, no run result)
On the spark plug coil connectors I'm getting 12V on the first wire & 5V on the second wire.
On the  connector/wiring going into the TBPS (whatever its called, the drive by wire throttle body position sensor)
I'm getting
4.94V on the first wire (yellow)
5.06V on the second wire (white)
4.94V on the third wire (grey)
I haven't tried replacing the throttle body assembly yet but again, have a feeling its something else, but i could be wrong. Is there a simple procedure to test the resistance or something on the throttle body to cross that off the list?
Hope I provided enough info without going over board. Any suggestions are appreciated.
Thanks, Justin
Justin
French or Canadian built ?
Do you have power to Dome, cig lighter, ETCS, hazards or headlights ? - the Dome fuse feeds the control side of the Acc relay
double-check the fusible links, it should be 120a and a 60a
Have a look on www.toyota-tech.eu for wiring diagrams for your car. It's chargeable by time, but you can download the documents you are interested in and keep them offline. Unfortunately, it may not have US specific wiring diagrams, but it's worth looking to find out. It isn't just wiring diagrams, by the way, it should also have diagnostic steps and other workshop information.
Toyota-tech.eu is Europe only. iirc the NA equivalent is techinfo.toyota.com
wiring diagrams and info not an issue, i have access to most of them
This 1.5L 1nz says Made in Japan (but they could say that and still be assembled elsewhere)
Thanks for the info about the dome fuse feeding the control side of the Acc relay. I don't have 12V power going into the Dome light fuse and also the ETCS fuse.  Didn't notice the Hazards, Headlights, and Cig lighter not working yet but I would assume they aren't working either and will only take seconds to check/confirm.
will double check the fusible links. Question? There aren't any other fusible links besides the Battery positive terminal fusible link assembly that consists of the 120a alternator and 60a links correct?
Thanks, missed this searching online as I was generally searching on forums and video sites. I don't own a Toyota myself so I was completely unaware of this resource.
appreciate the clarification. Visited techinfo. briefly and will be trying it out the next couple days.
I take it the fusible link block has been changed, and the cables have been seated correctly
what are the first 3 letters of the VIN ?
