Help p0340 code
TR1ND3R92
Hi hoping someone can help me I have a Toyota yaris 2005 1.3vvti 2sz engine, the timing chain has been changed and before and after I have been getting this camshaft position sensor code p0340. I have changed the camshaft sensor and crankshaft sensor to rule them out the timing is right, I've checked the voltage on the connector on the harness and one wire was saying 11.70v and the other is saying over 12v. Fault code won't clear. the car drives as normal just when sitting still sounds like it's misfiring and idles high.
I hope someone can help thanks for reading
Thanks I hope so, could really do with some advice, can't be the only one who has had this issue
