Diesel Injector Part numbers
TomPiper
Hi all and thanks in advance for any help you can give.
I've got a 2009 2.2 D-Cat and I need to source an injector or two. The part number on the ones I've had removed is 23670-0R090.
My question is, does this have to be identical or are there other slightly different numbers which are compatible? I ask because sometimes an injector I've found for sale has multiple, slightly different numbers referenced.
Thanks again
Thanks again
Would need your chassis number to confirm part numbers however Toyota offer Denso reconditioned injectors from £204 each + vat.
