Whirring noise clutch on Yaris
Polo3454
When I'm on the friction point of the clutch in 1st speed it makes that noise. The noise disappear as soon as the clutch is press or depress.
Strangely, the noise start to appear each time after touching the steering for my first turn (to the left or right). It looks odd that this could be related.
It's a Yaris 2001, I bought it a couple of days ago. I know it's a old car, but it fullfil my needs.
If its ok when going straight ahead and operating clutch look at the steering system is hydrolic fluid level correct.
I would have said thrust bearing but you said it stops when you push the pedal all the way in.
That doesn't sound like clutch bearing to me
1. check the wheel bolts are tight
2. what condition are the front pads and discs in ?
3. does it make the sound in reverse ?
4. does it feel like it need more rpm to pull away ?
