Locking Ecu
aka
hi,
the central locking system on my avensis 2.0 gls 1998 has taken to intermittently locking by itself. the remote key also seems to frequently stop working, and needs synch'ing.
does anyone have any ideas ?
how can i find the alarm/locking ECU to see if anything has come loose ?
thank you
andy
Check the dome fuse as that also runs the central locking, try replacing it just incase it's getting a bit dodgy. As regards locking, the car does auto lock itself after being unlocked and un-used for a few seconds.
Try the fuse, might have a bit of moisture in it even.
These problems are usually caused by the simplest of things.
Hello aka,
Check the area where james suggested. Also, check the door swich on all 4 doors. I have seen cases where one of those switches crack causing the symptom you described. You can test them by pressing with your fingers to see whether it is working properly. But remember, to look at the door adjar warning on the meter panel to see if the light comes on or off. If you look at the courtesy dome light on the ceiling, it has a delay so you might mistake it for not working so best to look at the meter panel.
Hope it gets sorted soon. :thumbsup:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
